Guide SSL/TLS Errors in Desktop Clients
Eggy BNC expects an encrypted connection on port 5000.
Common TLS-related errors include:
  • SSL handshake failed.
  • Wrong version number.
  • Connection reset.
  • The remote host closed the connection.
  • Unable to establish a secure connection.
  • Connection aborted immediately.
Check the client configuration
Use:
Server: bnc.eggy.net
For mIRC-style commands, use:
+5000
rather than:
5000
Do not disable certificate checks unnecessarily
A username, password or network-name error is not fixed by disabling certificate validation.
First confirm:
  • The correct server.
  • The correct port.
  • SSL/TLS is enabled.
  • The system date and time are correct.
  • The client is reasonably current.
Include the exact certificate or TLS error in your support thread rather than describing it only as a connection failure.
