Saving Eggy BNC in mIRC
You can save the connection in mIRC instead of entering the command manually each time.
Create a server entry using:
The server password must use:
Separate entry for each IRC network
Each dashboard network requires a different password value.
For example:
You may find it clearer to save separate entries such as:
All entries use the same server and port, but each one uses its own dashboard network name.
After changing your password
Update every saved mIRC entry.
An entry that still contains the previous password will fail the next time it reconnects.
Description: Eggy BNC
Address: bnc.eggy.net
Username/Network:Password
For example:
ExampleUser/Libera:Password
ExampleUser/DALnet:Password
ExampleUser/Undernet:Password
- Eggy BNC — Libera.
- Eggy BNC — DALnet.
- Eggy BNC — Undernet.
