QuakeNet Connection Guide
The current QuakeNet preset is:
Why the IPv6 server is used
The
Using the normal
Recommended settings
If the network remains disconnected
Check:
Authentication with QuakeNet services is separate from your Eggy BNC account password.
Network: QuakeNet
Server: irc6.quakenet.org
Port: 6667
SSL/TLS: Disabled
The
irc6.quakenet.org address is used for compatibility with Eggy IPv6 vHosts.Using the normal
irc.quakenet.org address may result in an IPv4 route that cannot use the selected IPv6 bindhost.Recommended settings
- Server:
irc6.quakenet.org - Port:
6667 - SSL/TLS: Disabled
- Nickname: A valid QuakeNet nickname
Check:
- Whether the hostname resolves over IPv6.
- Whether the selected vHost is active.
- Whether port 6667 remains selected.
- Whether SSL/TLS was accidentally enabled.
- The exact QuakeNet error message.
