OFTC Connection Guide
The current dashboard preset for OFTC is:
Recommended setup
If irc.oftc.net does not connect
Check:
Do not replace the server with a random hostname from an old guide.
Use a currently supported OFTC server and match its documented port and encryption requirements.
Nickname registration, channel registration and network bans are controlled by OFTC rather than Eggy BNC.
Network: OFTC
Server: irc.oftc.net
Port: 6697
Recommended setup
- Select the OFTC preset.
- Keep port 6697.
- Keep SSL/TLS enabled.
- Enter a valid nickname.
- Save the network.
Check:
- The exact connection error.
- Whether SSL/TLS remains enabled.
- Whether the hostname resolves.
- Whether the selected vHost is compatible with the server route.
- Whether OFTC is currently experiencing a server issue.
