Guide How to Enable IRC Inbox
IRC Inbox must be enabled before private-message threads can be discovered in the dashboard.
Enable the feature
  1. Sign in to the dashboard.
  2. Open IRC Inbox.
  3. Find Inbox Settings.
  4. Enable Enable IRC Inbox logging for this account.
  5. Choose whether message previews should be shown.
  6. Select a retention period.
  7. Select Save IRC Inbox Settings.
Module status
After saving, review the module-status field.
Expected status:
Eggy BNC inbox module active
The status may also confirm that the inbox folder is ready.
If the module remains inactive
Save the settings again once to re-synchronise the account.
If it still reports as inactive:
  • Refresh the dashboard.
  • Confirm Premium is active.
  • Record the exact module-status message.
  • Create an IRC Inbox Support thread.
Private-message threads will appear after IRC Inbox is enabled and supported thread data has been created.
