Guide Dashboard Buttons Stuck on Loading
Many dashboard actions are processed without requiring a full page reload.
While an action is running, a button may temporarily display a loading or processing state.
Do not submit the action repeatedly
Repeated clicks can:
  • Create duplicate requests.
  • Cause overlapping reconnect attempts.
  • Make the result difficult to diagnose.
  • Leave the visible page behind the live account state.
First checks
  1. Wait at least several seconds for the action to finish.
  2. Check whether a success or error message appeared elsewhere on the card.
  3. Refresh the dashboard once.
  4. Check whether the requested change was actually applied.
  5. Try a private browser window.
  6. Disable script-blocking extensions temporarily.
Common causes
A dashboard action may appear stuck because:
  • The browser blocked JavaScript.
  • The session expired.
  • The live helper request is still completing.
  • The external IRC server is taking time to reconnect.
  • The page received an invalid response.
  • A browser extension altered the request.
When reporting the problem
Include:
  • The dashboard area.
  • The exact button selected.
  • The affected network.
  • The approximate time.
  • What the button displayed.
  • Whether the change appeared after refreshing.
  • Any visible error message.
Do not post your password or full authenticated connection command.
