DALnet Connection Guide
The current dashboard preset for DALnet is:
Recommended dashboard settings
Connection errors
If the network does not connect, record the complete server error before replacing the server.
Possible issues include:
Using a specific DALnet server
A particular regional DALnet server can be entered through the network edit controls.
Confirm that the selected server supports the port and SSL/TLS mode you configure.
Do not repeatedly switch servers without recording the error returned by each one.
Network: DALnet
Server: irc.dal.net
Port: 6697
- Choose the DALnet preset.
- Use irc.dal.net unless a specific DALnet server is required.
- Keep port 6697 selected.
- Keep SSL/TLS enabled.
- Choose your preferred IRC nickname.
Connection errors
- A temporary DALnet server problem.
- A connection limit on the selected server.
- An unavailable route.
- Incorrect TLS settings.
- A nickname or registration requirement.
- A server that does not support the address family required by the active vHost.
