Guide Connecting to Several IRC Networks
Each IRC network stored in the dashboard has its own BNC connection identity.
All networks use:
Server: bnc.eggy.net
The network name inside the server password changes.
Example:
ExampleUser/Libera:Password
ExampleUser/DALnet:Password
ExampleUser/OFTC:Password
Recommended setup
Create a separate saved connection for every dashboard network.
Name them clearly:
  • Eggy BNC — Libera.
  • Eggy BNC — DALnet.
  • Eggy BNC — OFTC.
This prevents you from accidentally using the wrong network label.
Do not reuse one entry for every network
Changing only the nickname does not select a different BNC network.
The network is selected by the value after the slash:
Username/Network
Client network limits
Some desktop clients open each connection in a separate window or tab.
This is normal and does not create additional BNC networks in your dashboard.
