Guide Connecting to Multiple IRC Networks
Each network stored in your dashboard has its own connection format.
All connections use:
Server: bnc.eggy.net
The network name inside the password field changes.
Example:
ExampleUser/Libera:Password
ExampleUser/DALnet:Password
ExampleUser/OFTC:Password
Recommended setup
Create a separate saved entry for every dashboard network.
Use names such as:
  • Eggy BNC — Libera.
  • Eggy BNC — DALnet.
  • Eggy BNC — OFTC.
This prevents the wrong dashboard network name from being used.
Changing nickname does not select the network
The network is selected by:
Username/Network
Changing only the nickname field in your IRC client does not switch to another BNC network.
Use the separate connection format generated for each dashboard network.
