Guide An IRC Network Will Not Connect
If you can connect to Eggy BNC but one of your IRC networks remains disconnected, the problem is usually within that network's saved connection details.
Open:
Dashboard → Networks
Check the affected network.
Server address
Confirm that the server hostname is valid and currently offered by the IRC network.
Examples:
irc.libera.chat
irc.oftc.net
irc.dal.net
irc6.undernet.org
irc6.quakenet.org
Port and SSL/TLS
Common combinations include:
+6697 — SSL/TLS
6667  — Non-TLS
The server must support the selected port and encryption mode.
Do not assume every network offers SSL/TLS on the same port.
Nickname
Check that:
  • The nickname is valid for that network.
  • It does not contain unsupported characters.
  • An alternative nickname is available where required.
  • The nickname has not been rejected or reserved.
Reconnect the network
After correcting the settings, save the network and use its Reconnect control.
Avoid submitting repeated reconnect requests while the previous attempt is still processing.
If the network still fails
Create a Connection Help thread containing:
  • The network name.
  • The saved server and port.
  • Whether SSL/TLS is enabled.
  • The exact error shown.
  • The approximate failure time.
Do not include your password.
